Delete files from sourcefolders after writing and copying
  • Jul 15, 2022 2:22 PM UTC
  • 504 views
franco69
Forum|alt.badge.img+11
Hi guys......
i have a workflow where i source .xls files out from 3 different folders  e.g. C:\\temp\\PA8\\Lists, C:\\temp\\PA9\\Lists, C:\\temp\\PA7\\Lists
and split them (about an specified attribute) into many .xls files into another folder
e.g C:\\temp\\PA8\\splits, C:\\temp\\PA9\\splits, C:\\temp\\PA9\\splits
and additionaly i copy the source files with the filecopy writer into another folder
e.g C:\\temp\\PA8\\done, C:\\temp\\PA9\\done, C:\\temp\\PA9\\done
all that is working well!!!
BUT i want to empty the source folder after this processing in the same workflow......is this possible.....i have tried the Custom transformer File Deleter but i didnt get it how it works....any solutions or workarounds?
Cheers and Greetz
Franco
Best answer by muzhnasto
Hi @franco69​ why can't you set the MOVE parameter instead of COPY at this stage?
"and additionaly i copy the source files with the filecopy writer into another folder
e.g C:\\temp\\PA8\\done, C:\\temp\\PA9\\done, C:\\temp\\PA9\\done"
imageor read https://community.safe.com/s/question/0D54Q000080hRpdSAE/file-copy-delete
muzhnasto
Forum|alt.badge.img+12
  • Jul 15, 2022 3:10 PM UTC
franco69
  • Jul 15, 2022 3:15 PM UTC
oh.....i didnt see that.......cool.....thx for that
you saved my day
