Dear FME-community, I have a question about converting point-clouds in the xyz ASCII file type into 3D-meshes (like fbx or obj format)
  • February 4, 2021
  • 109 views
I have a folder containing over 200 xyz-files. Each xyz-file contains hundrets or thousands of point coordinates. So it is basically a text-file in the xyz-format. There are no other specififactions in the files, so only the coordinates.
I would like to convert each xyz-file into a mesh-file (like fbx or obj). It shoud have the best quality and use the least amound of disc-space.
I am looking for a way to automate the conversion. So when I click "run" over 200 fbx-files (or obj-files) are created with only one click. Down below, you can see a screenshot of the xyz-file. There are no headlines, that indicate which number is the x, y or z coordinate, but I am assuming it is in the order as the filename suggests.
I thank you very much for your help in advance!
screenshot
caracadrian
Forum|alt.badge.img+23
  • February 4, 2021
Add all your files as Single Merged Feature Type, go to Parameters, uncheck File Has Field Names, set the Components to x, y and z, click OK and OK to add them.
Use the PointCloudSurfaceBuilder to generate your mesh and chose the writer of your choice.
