Creation of nested (multilevel) JSON
  • Jun 2, 2022 10:19 AM UTC
  • 1415 views
albinepro
Forum|alt.badge.img+7
I want to create multi-level JSON (nested) with a specific attribution. I have followed this article. I need to get this structure:
Following the tutorial I'm not able to add more attributes to the top layer as is written also in JSONTemplater help. I need to get something like this:
"category": "kategorie1",
    "caption": "A",
"features" : [
         "name" : "A1",
         "rotation" : "0",
         "bbox" : [ -733690, -1024463, -732733, -1023916 ]
         "name" : "A2",
         "rotation" : "0",
         "bbox" : [ -733093, -1024114, -732939, -1023902 ]
   "category": "kategorie2",
   "caption": "B",
   "features" : [
         "name" : "B1",
         "rotation" : "0",
         "bbox" : [ -732924, -1023936, -732707, -1023601 ]
         "name" : "B2",
         "rotation" : "0",
         "bbox" : [ -733058, -1023918, -732884, -1023584 ]
All I can get so far is this:
   "A" : [
         "name" : "A1",
         "rotation" : "0",
         "bbox" : [ "-733690", "-1024463", "-732733", "-1023916" ]
         "name" : "A2",
         "rotation" : "0",
   "B" : [
         "name" : "B1",
         "rotation" : "0",
         "name" : "B2",
         "rotation" : "0",
My Templater setup is as follows:
ROOT
    fme:process-features("OBLAST")
OBLAST sub-template
       fme:get-attribute("pismeno") : [
        fme:process-features("PRVKY", "pismeno", fme:get-attribute("pismeno"))
PRVKY sub-template
                "name": fme:get-attribute("CISLO"),
"rotation":"0",
                "bbox": [fme:get-attribute("_xmin"),fme:get-attribute("_ymin"),fme:get-attribute("_xmax"),fme:get-attribute("_ymax")]
I would need to have the top level as separated object with more key-value pairs (attributes) as shown above - like in the last level features. If I try to add keys as in PRVKY sub-template to the OBLAST sub-template I get parsing error with invalid syntax.
Can someone guide me, please? I attach complete files. What I can get (bookmarks.json) and what I would like to get (bookmarks_desired.json).
Best answer by debbiatsafe
I have tried this, but still I'm getting the parsing error:
JSONTemplater (XMLTemplaterFactory): The following error occurred near line 5, column 37 of the query:
JSONTemplater (XMLTemplaterFactory): invalid expression: syntax error, unexpected ":", expecting "," or "}"
JSONTemplater (XMLTemplaterFactory): An error occurred while parsing the 'OBLAST' sub-template
JSONTemplater (XMLTemplaterFactory): A fatal error has occurred. Check the logfile above for details
 I have added two workspaces with test data to original posted question with working and not working (desired) workspace.
Hello @albinepro​
You have an extra XQuery expression in your OBLAST sub-template. This creates invalid JSON and causes the JSONTemplater to error.
Remove the extra fme:get-attribute("pisemeno") from the OBLAST sub-template so becomes this:
    "oblasti" : fme:get-attribute("pismeno"),
    "caption" : fme:get-attribute("CISLO"),
    "features":[fme:process-features("PRVKY", "pismeno", fme:get-attribute("pismeno"))]
In addition, remove the pipe operators in the ROOT template as it is unnecessary. Attached is an updated version of your workspace with the suggested changes.
debbiatsafe
Forum|alt.badge.img+24
Hi @albinepro​
JSON key-value pairs need to be separated by commas. Based on the sub-template you have shared, it appears you are missing these. For example, based on your desired output, your OBLAST sub-template should look something like this:
"caption" : fme:get-attribute("caption"),
"features": [
If you're still running into issues after making this change, I would recommend sharing your workspace along with a small sample of your input data.
albinepro
  • Jun 3, 2022 7:21 AM UTC
Hi @albinepro​
"features": [
debbiatsafe
  • Jun 3, 2022 7:53 PM UTC
Hello @albinepro​
albinepro
  • Jun 6, 2022 7:43 AM UTC
Great, thanks a lot. Somehow I thought it is essential. The pipe symbols in root hence are not necessarry neither.
