Counter generate IDs
  • Oct 4, 2022 2:41 PM UTC
  • 14 replies
  • 331 views
asadamjad
Participant
Forum|alt.badge.img+12
I have one table where id already there now what I want is when I push the new data it will generate an automatic id
for example the Table ID is 47 and when I push new data then that table insert from 48 in ID columns
I use a counter to generate the ID from new data and then I use the static calculator from Table so it gives me a max number of 47 and when running that wS then it's not generate the ids
Best answer by carmijo
so how can i do that ??
  1. locate an attribute that's populated for all your features coming out of attributremanager_4
  2. add a sorter
  3. feed features from attributemanager_4 and statisticscalculator to the sorter
  4. setup the sorter to sort by the attribute that you picked in step 1, ascendingimage
  5. then the first feature to hit the counter will have the id.max attribute populated
carmijo
  • Oct 4, 2022 2:52 PM UTC
Hi @asadamjad​ You can send the max value from the statistics calculator to the Count Start parameter of the Counter. That way the counter will start at the correct id value. To do this, you may need to add the max ID value to the data you want to add the ID to.
image--
If i've provided something helpful, please upvote the comment. If i've provided a solution, please mark it as 'Best Answer'. This helps the community find solutions when your question is referenced.
If I didn't provide a solution, please let me know if I can help further. Thanks! 🙂
asadamjad
Participant
  • Participant
  • Oct 4, 2022 2:56 PM UTC
thats what i m doing still not working
asadamjad
Participant
  • Participant
  • Oct 4, 2022 2:58 PM UTC
still rejecting
carmijo
  • Oct 4, 2022 2:59 PM UTC
still rejecting
I attached a screenshot with a better explanation. take a look and see if that helps.
asadamjad
Participant
  • Participant
  • Oct 4, 2022 3:01 PM UTC
check my SS as well please
carmijo
  • Oct 4, 2022 3:05 PM UTC
I did but it's difficult to understand where the problem is since no parameter values are showing. i would recommend attaching a summary annotation to the primary transformers like the counter_3 and counter
asadamjad
Participant
  • Participant
  • Oct 4, 2022 3:12 PM UTC
Please see the attached File
carmijo
  • Oct 4, 2022 3:18 PM UTC
from your workspace. see the tan colored annotation
asadamjad
Participant
  • Participant
  • Oct 4, 2022 3:53 PM UTC
still not rejecting
asadamjad
Participant
  • Participant
  • Oct 4, 2022 3:56 PM UTC
carmijo
  • Oct 4, 2022 5:18 PM UTC
I see. it's probably because the other features are getting to the counter before the feature from the statistics calculator. So it's trying to start counting but it doesn't know id.max at this point. you'll want to feed both streams into a sorter and sort in a way that the record with the id.max value enters the counter first
asadamjad
Participant
  • Participant
  • Oct 4, 2022 5:22 PM UTC
asadamjad
Participant
  • Participant
  • Oct 4, 2022 5:26 PM UTC
still not
carmijo
  • Oct 4, 2022 5:36 PM UTC
  2. add a sorter
