Change the location of FME feature Store file
  • May 28, 2018 5:17 PM UTC
  • 435 views
dos_gis
Forum|alt.badge.img+3
I'm running out of disk space for the default location of the feature store C:\\Users\\user \\AppData\\Local\\Temp\\. I'd like to change the location of the feature store to a different hard drive. I've change the environmental variable of the TEMP folder but this didn't update the location of the feature store?
Best answer by andreaatsafe
Hi @dos_gis,
You likely need to re-start your machine after setting the FME_TEMP environment variable.
In addition, I would ensure that the folder/path name of the new TEMP folder does not have any spaces or special characters in it to prevent any other problems.
Let us know if you are still encountering a problem.
diwanicka
Forum|alt.badge.img+4
  • May 28, 2018 5:28 PM UTC
Hi @dos_gis
If you add the FME_TEMP environment variable and then specify the path this will change you temp folder for FME.
https://knowledge.safe.com/articles/176/fme-temp-environment-variable.html
dos_gis
  • May 28, 2018 5:59 PM UTC
I did that. Unfortunately, it didn't help. I need to change the location of the Feature Store:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/ffs/ffs.htm
andreaatsafe
Forum|alt.badge.img+17
  • May 28, 2018 11:21 PM UTC
Hi @dos_gis,
