Can't get simple regular expression to work
  • May 20, 2021 8:48 PM UTC
  • 6 replies
  • 100 views
Dear smarter people than me -
I have a cad files with layers that start with either A- or C- and then one basemap layer called Mad_PARCELS. In my reader I only want to read the A- and C- layers. How would I query this out in the Merge feature type using regular expression. Or how do you combing two wildcard expressions? I can't really find any good documentation on regular expression examples. TIA
Best answer by gazza
Thanks!
Neither of those worked (nothing passed through). I tried those (or something similar, I don't remember, I tried probably 50 different iterations before posting). So there must be something else going on with my workbench (or my source DWG). But I at least know I was on the right track now, so I can go back and see what else it going on in that workbench, or at least break it down step by step.
I appreciate the quick response.
I think I have it:
^[AC]-\\S+
This means, Starts with A or C, followed by -, followed by any number of other characters.
gazza
  • May 20, 2021 9:30 PM UTC
With RegEx a ^ means start of string and a | means OR, so you probably want something like:
^A-|^C-
gazza
  • May 20, 2021 9:37 PM UTC
^A-|^C-
Or you could use:
^[AC]-
which means, start of the string is either an A or a C then a -
  • May 21, 2021 1:11 PM UTC
Thanks!
gazza
  • May 21, 2021 11:02 PM UTC
Thanks!
I think I have it:
^[AC]-\\S+
  • May 24, 2021 7:56 PM UTC
I think I have it:
^[AC]-\\S+
Thanks so much for the additional research on this. This did work. I ended up just doing a tester to remove that one layer, but it takes so long to go through the 60K features on that one layer. I tested and it reads this way soooo much faster, so I really appreciate that, I don't think I would have gotten that one.
gazza
  • May 24, 2021 8:30 PM UTC
I think I have it:
^[AC]-\\S+
You are welcome, glad it works. The trick was that the RegEx needs to match the entire layer name not just the first few characters.
