Can't create excel file in FME server.
  • Nov 1, 2021 1:17 PM UTC
  • 103 views
souryana
Forum|alt.badge.img+12
I have problem creating an excelfile in a script that I published in FME server. I get an outputfile with type "file" and not ".xlsx". I can use the file to drag and drop it to an empty excel sheet. However what I really want to do is to create an excelfile. I am using a published parameter in my writer that looks like this .image Also please check my parameters for the excelwriter.
imageAm i missing something important?
The version on FME desktop: 2020.1.3.0
The version on FME server: 2020.2.3
itsmatt
Forum|alt.badge.img+48
  • Nov 1, 2021 2:36 PM UTC
I think you might just need to specify the extension in the parameter when running it. Is there a reason you can't/don't want to include an extension?
souryana
  • Nov 1, 2021 2:48 PM UTC
Hi, thanks! I thought the extenstion came from the configuration parameter. But now I know that I need to specify the extension in the Default value parameter!
Regards
