calculate sum value of some rows which have identical row id in one row using aggregator
  • September 9, 2022
  • 246 views
arash_hokm
Forum|alt.badge.img+8
I have a table in which some rows have identical values. I would merge the identical rows into one by using aggrator.
I want the sum of row values ​​to be written to a new row.
the aggragator does not calculate a sum of the values.
Attached you will find the pictures that may help you to better understand my description.
aggragator_Problemcolumn Anzahl_Gas_HA must be 2177 after using aggregator.
Best answer by caracadrian
Set GroupBy to Zone and Attributes to Sum Anzahl_Gas_HA:
Aggregator GropuBy SumIf the sum isn't coming out right send the features through AttributeValidator with Anzahl_Gas_HA Type is Integer and check if there are no strings mixed with the numbers.
caracadrian
Forum|alt.badge.img+23
  • September 9, 2022
arash_hokm
  • September 9, 2022
Super. Thanx alot :)
