Batch deployment : given file does not exist
  • April 22, 2022
  • 40 views
Hello FME Community,
I have been working with batch files and all goes well when my reader and writter are in posgtresql but when my reader is in access(.mdb) file or excel it causes problems,it says that it cannt find the file where the file already exist and the strange things is that it worked once. When i created a new batch with same workflow and same file i get the following error. I seems a problem of url as the \\ are removed but i dont undarstand the cause of it.
log errorI'm attaching the .tcl files for the the workbench that works and doesnt work( they are exactly the same apart the name). The file that ends with 22 doesnt work and it has less code than the other one.
Thanks in advance for your help.
  • April 22, 2022
I also have tried a very simple workbench csv to csv like below
imageand i get this error :
CSV reader: Failed to open file 'C:Usersg-lamiDocumentsWorkbenchCSV.csv' for reading. Please ensure that the file exists and you have sufficient privileges to read it
the .tcl file is this one
#!/usr/bin/env fme
set workspacename {C:/Users/g-lami/Documents/Workbench/batch_test.fmw}
lappend destMacroList {DestDataset_CSV2_2}
lappend suffixList {}
lappend destDirList {C:/Users/g-lami/Documents/Workbench/}
lappend destDSetTypeList {2}
set recreateSourceTree "no"
set superBatchFileName [FME_TempFilename]
set superBatchFile [open $superBatchFileName "w"]
lappend sourceDatasets {C:/Users/g-lami/Documents/Workbench/CSV.csv}
set logStandardOut {}
set logTimings {}
set sourceDatasets [lsort [eval FME_RecursiveGlob $sourceDatasets]]
# When the "Recreate source directory tree" option has been selected,
# find the deepest directory that all of the source datasets have in common.
# This will be removed from each to form the destination dataset name.
set commonSource {}
if { [string first {yes} $recreateSourceTree] != -1 } {
  # And now the interesting part. We start out assuming that everything up
  # to the last "/" in the first dataset is the common part, and then
  # start shortening it until we've looked at all datasets.
  foreach dataset $sourceDatasets {
   regsub {/[^/]*/*$} $dataset / datasetDir
   if { $commonSource == {} } {
     # The first time through, we will take the whole dataset directory
     # to seed our notion of what's in common
     set commonSource "${datasetDir}"
   } else {
     # Compare this dataset's directory with our current notion of
     # the commonPart. We will iteratively remove path portions from
     # the end one or the other (or both) until they match.
     while { $datasetDir != $commonSource } {
      if { [string length $datasetDir] >= [string length $commonSource] } {
        regsub {[^/]*/*$} $datasetDir {} datasetDir
      } else {
        if { [string length $commonSource] >= [string length $datasetDir] } {
         regsub {[^/]*/*$} $commonSource {} commonSource
set spot 0
set numDatasets [llength $sourceDatasets]
set extraDatasets {}
set showProgress 0
while {$spot < $numDatasets} {
  set nextSpot $spot
  incr nextSpot;
  set curDataset [lindex $sourceDatasets $spot]
  set curSourceDirectory [file dirname [file rootname $curDataset] ]
  # If we are replicating the directory structure, remove the common
  # portion of the source dataset, and use it in the formation of the
  # destination dataset.
  if { ($commonSource != {}) &&
     ([string first $commonSource $curSourceDirectory] == 0) } {
    set baseName [string range $curSourceDirectory [string length $commonSource] end]
    set destIndex 0
    set numDest [llength $destDirList]
    while {$destIndex < $numDest} {
     set destDir [lindex $destDirList $destIndex]
     set destDSetType [lindex $destDSetTypeList $destIndex]
     incr destIndex
     if { $destDSetType == 1} {
       catch { file mkdir [file dirname $destDir] }
     } else {
       catch { file mkdir [file dirname $destDir$baseName] }
  } else {
    set baseName [file tail [file rootname $curSourceDirectory]]
     ([string first $baseName $commonSource] != -1) } {
     set baseName {}
  set break 0
  if { ($nextSpot < $numDatasets) } {
    set nextDataset [lindex $sourceDatasets $nextSpot]
    set nextSourceDirectory [file dirname [file rootname $nextDataset] ]
    if { ($nextSourceDirectory != $curSourceDirectory) ||
       ([lsearch $destDSetTypeList 0] == -1) } {
      set break 1
      set showProgress 1
    } else {
      # Add to the list of like datasets
      set extraDatasets "$extraDatasets +CSV2_1_DATASET \\"$curDataset\\""
  } else {
    set break 1
  if { $break == 1 } {
    set destDatasetLine {}
    set destIndex 0
      set suffix [lindex $suffixList $destIndex]
        set destDataset "$destDir$suffix"
      } else {
        set destDataset "$destDir$baseName$suffix"
      set destDatasetLine "$destDatasetLine --[lindex $destMacroList \\"$destIndex\\"] \\"$destDataset\\""
      incr destIndex
    if { $showProgress == 1 } { puts $superBatchFile "INCLUDE \\[puts_real \\"\\\\nProcessing $curDataset ([expr $spot+1] of $numDatasets)\\\\n\\" \\] " }
    puts $superBatchFile "\\"$workspacename\\" --SourceDataset_CSV2_1 \\"$curDataset\\" $destDatasetLine $extraDatasets $logStandardOut $logTimings"
  incr spot
close $superBatchFile
set fmeHome {}
catch { set fmeHome $::env(FME_HOME)/ }
if [ catch { ${fmeHome}fme COMMAND_FILE $superBatchFileName } err ] {
 puts $err
 puts "\\nFME encountered an error. Please contact http://www.safe.com/support"
} else {
 puts "\\nTranslation SUCCESSFUL"
if [ catch { file delete $superBatchFileName } ] {
 puts "Warning: unable to delete $superBatchFileName"
