Base64 Image To Oracle Blob To Base64 Image
deanhowell
Forum|alt.badge.img+23
Hello everyone,
I am storing a range of base64 PNG images as blobs in an Oracle Table.
As part of a separate process, I want to read these images from Oracle and use them in an HTML report.
What I am noticing is the attribute being written to Oracle is different to what is being returned from Oracle.
Attributes when written to OracleimageAttribute from Oracle
imageWhat do I need to do to read / write the image so I can use the Base64 version as an attribute in the HTML writer?
  • July 11, 2022
Any particular reason for base64-encoding the images before storing them in the BLOB? Why not simply store the binary file in the BLOB directly, without having to go through base64?
deanhowell
  • July 11, 2022
Good question @david_r​ and the main reason is that I am using base64 in my HTML for example
<img src="data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAUAAAAFCAYAAACNbyblAAAAHElEQVQI12P4
//8/w38GIAXDIBKE0DHxgljNBAAO9TXL0Y4OHwAAAABJRU5ErkJggg==" alt="Red dot" />
So I want to be able to use the attribute
<img src="data:image/png;base64,@value(RasterBlob)" alt="Red dot" />
  • July 11, 2022
I would still just store the PNG as-is in the BLOB, then convert it to base64 at the last minute when generating the html.
BLOB is a binary data type, so it makes sense to store binary data, such as the PNG file contents, in it. Base64 is a text format, so it would be easier to simply store it as a CLOB in Oracle, rather than a BLOB.
deanhowell
  • July 11, 2022
Thanks again, I will give that a go :)
