AttributeKeeper keeps the attribute only for the first feature
  • Jan 18, 2022 10:08 PM UTC
  • 72 views
Hello,
I'd like to "remember" an attribute and use it to populate an attribute of another feature in the same execution.
I thought AttributeKepper would do the job (because of the name haha), but the value of the attribute is empty, except in the first pass through the breakpoint.
caracadrian
Forum|alt.badge.img+23
  • Jan 19, 2022 6:14 AM UTC
Can you give us a more detailed example of what you would like to do? Maybe a sample of your work.
nielsgerrits
Forum|alt.badge.img+67
Do you want to use an attribute from a previous row? You can do this in an AttributeCreator using "Adjacent Feature Attributes":
AttributeCreatorParameters
  • Jan 19, 2022 5:14 PM UTC
Many thanks guys!
I have sorted it out. The problem was, I had 2 attributes / features going to the Supplier port of a FeatureMerger. Both come from an particular AttributeKeeper. The flow looked like this:
feature_merger1When I added a dedicated FeatureMerger for both, the behavior was as expected.
Thank you for your time!
