How can I turn off the alphabetical sorting of attribute names using the import feature of the attribute creator? There's a "Sorted" option in the wizard but it doesn't seem to do anything?
Hi dos_gis,
The sorted checkbox is applied to the result of the filter. You should enter some text into the filter box, then it should work.
I see that the filter box filters the attribute list. Toggling "sorted" doesn't seem to affect this?
Already have an account? Login
