ASCII to CSV
  • November 15, 2022
  • 408 views
wind
Hello,
How can I convert an ASCII file to xyz csv file please?
Thank you
Best answer by redgeographics
You could use a RasterCellCoercer to generate a point for every pixel and assign the band value as to an attribute automatically, then a CoordinateExtractor to get the x and y values too and write them out to a CSV file.
Alternatively, you may even get away with writing directly to a Point Cloud XYZ file.
Forum|alt.badge.img+50
This is a very generic question. If you want a specific answer it would help if you could show us what your ASCII file looks like. Or do you mean an ASCII grid file?
wind
  • November 17, 2022
Hello,
this is the file I want to convert. It's an numeric terrain model each 1m. So I need to have an csv file with coordinates and elevation like this: 893798.5, 6256850.5, 314image.pngThank you!
  • November 17, 2022
wind
  • November 17, 2022
It works!
Thank you very much
