Access FME Server Parameters in Workspace
  • Jul 28, 2021 2:39 PM UTC
  • 62 views
Hi I am looking for the best practice where to save an sde connection file when publishing to FME Server.
I am thinking to determine the location of the sde connection file using scripted parameter as below.
However when I run the workspace, I get ERROR : Python Exception <KeyError>: 'FME_SHAREDRESOURCE_DATA'
Any suggestions?
import fmeobjects
if FME_MacroValues['FME_SHAREDRESOURCE_DATA']:
  # Running on FME Server
  return FME_MacroValues['FME_SHAREDRESOURCE_DATA'] + 'connectionFiles/sdefile.sde'
else:
  #Running on FME Desktop
  return '../config/sdefile.sde'
Got it working using Get() method FME_MacroValues dictionary
FME_MacroValues.get('FME_SHAREDRESOURCE_DATA')
