3d tileset validation error for cesium js
Hi, FME community
I hope everyone is doing great, I am creating 3d tileset for cesium js and it is getting created successfully, but when I am using 3d tile validator tool(cesium team has implemented a validator tool here https://github.com/CesiumGS/3d-tiles-validator) then I am getting my tileset is invalid because of some errors, I do not know how to overcome of these errors using FME, please anyone if knows how to fix these errors, please let me know. please find the errors below:-
  "type": "CONTENT_VALIDATION_ERROR",
   "path": "data/data7.b3dm",
   "message": "data/data7.b3dm caused validation errors",
   "severity": "ERROR",
   "causes": [
     "type": "BINARY_INVALID_ALIGNMENT",
     "message": "The byte length must be aligned to 8 bytes",
     "severity": "ERROR"
   "path": "data/data6.b3dm",
   "message": "data/data6.b3dm caused validation errors",
   "causes": [
     "severity": "ERROR"
   "path": "data/data5.b3dm",
   "message": "data/data5.b3dm caused validation errors",
   "causes": [
     "severity": "ERROR"
  • June 2, 2023
With respect to above issue, is it possible to set "The byte length must be aligned to 8 bytes" byte length Using FME.
Please suggest.
Dear FME Community,
I am new to Cesium, using FME tool able to convert CityGML to Cesium 3D Tileset.
During Conversion process, no bug or error popupped, yet while validate using 3D Tiles validator, https://github.com/CesiumGS/3d-tiles-validator given the following report.
“date”: “2023-06-02T06:42:48.564Z”,
  • “numErrors”: 1,*
  • “numWarnings”: 0,*
  • “numInfos”: 0,*
  • “issues”: [*
  • "type": "CONTENT_VALIDATION_ERROR",*
  • "path": "data/data0.b3dm",*
  • "message": "data/data0.b3dm caused validation errors",*
  • "severity": "ERROR",*
  • "causes": [*
  • "type": "BINARY_INVALID_ALIGNMENT",*
  • "message": "The byte length must be aligned to 8 bytes",*
  • "severity": "ERROR"*
need Help to solve the error using FME.
I was stuck like anything and unable to crack or get valid insights from internet too.
If anyone has these kind of issue earlier, please let me know how-to overcome it.
Thanks in Advance.
I am a bit sad to know that No one knows in FME community, how to resolve above issue. I hope someone experienced in FME will see it one day and give some solutions/suggestions, how to overcome the above issue.
Thanks
Basant
