Is there a way to customize the webhook url in FME flow hosted?
  • Jul 10, 2023 10:07 PM UTC
  • 131 views
candacel
keziaatsafe
Forum|alt.badge.img+8
Hi @Candace Low​ ,
Can you elaborate more on how you want to customize the webhook URL? Do you want to change the parameter values when running the workspace?
The Webhook URL contains all the required information to run a particular workspace from the web: the FME Flow (Server) domain, web service, repository, workspace, and any parameters and their values follow in a query string. This article may be a helpful resource for submitting a job through FME Flow webhook URLs.
Hope this helps!
Kezia
candacel
  • Jul 17, 2023 9:35 PM UTC
Hi @Candace Low​ ,
Hope this helps!
Kezia
Hello, we'd like to append something at the end to identify 'which' type of workspace is being run. This will be customer facing so we kind of want to use it like an api
Ex: https://fmecloudurl/?id=39688brb9-xxx/routes
OR
https://fmecloudurl/?id=887188brb9-xxx/addresses
keziaatsafe
OR
@Candace Low​ , thanks for the examples.
This is not something I've run into before but in my testing, if you add "&/routes" or "&/addresses", it should still run fine.
ex: http://fmecloudurl/service/repository/workspace?PublishedParameters&opt_showresult=false&opt_servicemode=sync&/route
Please note that this has not been thoroughly tested so I'd advise testing with your workspaces before pushing to PROD.
Hope this helps!
Kezia
