Import error when using paramiko and scp python libraries on FME Server
Hello everyone,
I'm using the paramiko and scp python libraries in a pythoncaller to transfer files from my local environment to a remote Linux server. When testing locally I received an import error which I could solve by removing all contents of C:\\Users\\<user>\\Documents\\FME\\Plugins\\Python and reinstalling paramiko and scp.
However, when I transferred the contents to the Plugin folder on my FME Server instance, managed by FME Cloud, I received the same import error I previously received on FME Desktop even though the Plugin folder on FME Server was empty to start with.
The import error I receive is formatted like this: Python Exception <ImportError>: cannot import name '_bycript' from partially initialized module 'bcrypt' (most likely due to a circular import) (/data/fmeserver/resources/engine/Plugins/Python/bcrypt).
The following python code is the source of the import error:
import paramiko
from scp import SCPClient
I noticed that the importerror might be related to the FME Version I am using. Both Desktop and Server are version 2021.2.5.0 Build 21816 WIN64. Locally It worked on an older version (2020.2.0.0 Build 20787 WIN64) before I reinstalled paramiko and scp to make it work on the 2021.2.5 version.
Thank you in advance for all the help.
Best answer by siennaatsafe
Hi @kd​
Do you know if paramiko and scp are OS specific? I've seen users need specific Linux libraries before.
What version of Python are you using? You may need to create a folder in FME Server if the version doesn't match the Python Compatibility setting in FME Desktop.
siennaatsafe
Forum|alt.badge.img+11
  • June 24, 2022
Hi @kd​
  • June 27, 2022
siennaatsafe wrote:
Hi @kd​
Hello Sienna,
I managed to fix the issue using your suggestions.
I first installed paramiko and scp on a Linux server. Then I copied those files to FME Server under a new subfolder 'Resources\\Engine\\Plugins\\Python\\python38'.
Thank you for helping me!
