Download Web Connection from FME Hosted
  • Jan 8, 2024 10:03 PM UTC
  • 286 views
johnglick
Forum|alt.badge.img+7
Hi, I recently switched FME Flow Desktop to a new machine and missed exporting my web connections. Is there a way to download them from FME Hosted?
j.botterill
Forum|alt.badge.img+69
  • Jan 9, 2024 12:31 AM UTC
Hi john, probably the easiest way to migrate connections is to go to the old machine and in the fme options db/web connections you can select connections and right click > export them as xml (placing an additional password to encrypt the .enc output). Then on the new machine, import them
There are other methods, including fme defaults to a connection store ttps://community.safe.com/s/article/making-database-and-web-connections-public
johnglick
  • Jan 11, 2024 6:46 PM UTC
I missed mentioning that my old machine was wiped, hence the need to download them from the server. Not a problem to rebuild them, but definitely takes some time.
