Upgrading FME Flow - dropping database configured on own server
  • Sep 16, 2024 12:18 PM UTC
  • 80 views
Forum|alt.badge.img+54
Is there a reason the FME database user has to be dropped and recreated when upgrading FME Flow, as opposed to just dropping all the schema objects?
Is it just because it’s simpler to drop and recreate?
toyosia
Forum|alt.badge.img+4
  • Sep 20, 2024 5:22 PM UTC
Hi @ebygomm ,
You are not required to drop the database user; however, you're correct that each version of FME Flow has a different Schema. As a result, it’s recommended to drop and recreate the database to ensure compatibility with the new version.
If you have any further questions, feel free to ask.
Thanks, Toyosi
