How to track job status based on Published Parameters?
  • Jun 7, 2024 5:04 AM UTC
  • 94 views
mayurasodariya3
Participant
Hello,
I am submitting job through my FME api and not keeping job id in application, Though I want to check status of my job through Published parameer which is always unique.
I know we can get all jobs and then we can do filtering but it will bit costly operation hence I dont want to do that.
How to track Submitted job status with Published parameter? (Eg: I am supplying  “batchId” as published parameter and want to track job status based on my that batchid only)
andrewj74
Forum|alt.badge.img+8
  • Jun 7, 2024 9:28 AM UTC
Cant you just look at the job log on FME server? or did you want them all logged on a spreadsheet or get an email notification. If you use an FME server automation you could expose the upstream workspace name and status to use in a subsequent workspace to create a log, or alternatively expose them in an email body to notify yourself.
