How to disable "Data Collection" via environment variable?
  • Dec 27, 2024 11:12 AM UTC
  • 149 views
peter.frohberg
Hi everyone,
after opdating FME Flow from 2024.0.3 to 2024.2.1 I’ve noticed that there is a (new?) “Data collection” optione within the Security Options.
We are using FME Flow via docker compose. Is it possible to disable the “Data collection” via a (Docker) environment variable so I don’t have to disable it manually after every update?
Greetings
Peter
Best answer by luke.hicks
Hi ​@peter.frohberg,
Unfortunately, there are currently no docker environment variables which can be used to disable data collection, and the current method is to manually deselect after your initial upgrade to 2024.2.1.
Your data collection setting is saved upon backup and restore, so for future upgrades (as long as you are restoring your data) the setting will remain as your previous setting.
If you have any further questions or concerns, please let me know either via a reply on this forum post, or by contacting our support.
Cheers,
   - Luke H
luke.hicks
Forum|alt.badge.img+11
  • Dec 30, 2024 7:54 PM UTC
Cheers,
   - Luke H
peter.frohberg
Hi Luke,
thanks for the quick and clear response. It’s good to know that the data collection setting is also backed up. :-)
Greetings,
Peter
