FME Flow Dependency
  • Mar 21, 2024 9:38 PM UTC
  • 0 replies
  • 166 views
mark2atsafe
Forum|alt.badge.img+59
I’m asking this question on behalf of a user who’s having trouble posting to the forum…
Hello Community,
I have recently run into a snag with FME Flow 2023.2.1 Build 23774 -win64
We are trying to build an FME Flow using a high availability SQL Server and I am stuck at the last step..
I have followed the steps posted on-line https://docs.safe.com/fme/html/FME-Flow/AdminGuide/Changing_Database_Provider.htm and now want to remove the Postgres database dependencieS. Yes there are 2 not just one.
I have stopped and disabled the database dependency on the FME Server Core Service as described: https://docs.safe.com/fme/html/FME-Flow/AdminGuide/Removing_Database_Service_Dependency.htm
I ran in Administrator command window  sc config "FME Server Core" depend= /
It removed that dependency.
The question is, there is still a dependency on the database by the FME Server Application Server service.
I am sure i will have more questions as I try to complete the process, but let’s start with this one.
Thanks
Eric Storie
