XML reader adds xsi:nil="true" elements as filed names with .nil how to resolve this and have the value populated to be null
  • Jan 24, 2019 5:52 PM UTC
  • 6 replies
  • 1508 views
bhanu_v
I'm reading an XML with ticket details that has xsi:nil=true in the tag and it adds the field name with .nil
Also,there is a tag with xlmns andIm not sure if I have to use a List Exploder to further get its attributes.
I'm a novice FME user and have no prior experience with xml either
I'm looking for direction on how to resolve the field names to be the tag text and populate its values in ESRI Gdb format
Any help will be much appreciated
Best answer by itay
Hello @adi, the
<test:PreviousTicketNumber xsi:nil="true" />
Just tells you that the PreviousTicketNumber attribute doesn't necessarily need to have a value (true), if you are only interested in the PreviousTicketNumber value you can ignore the PreviousTicketNumber.nil tag
itay
Forum|alt.badge.img+19
  • Jan 24, 2019 7:42 PM UTC
Hi @adi,
It would be useful if you can share the XML input so that we can assist you.
bhanu_v
  • Jan 24, 2019 9:28 PM UTC
Hi @adi,
Hello @itay
Thankyou for taking time to look into this ,
here is a sample xml ,its ticket information that Im trying to write into SQL ,or Esri gdb
<?xml version="1.0" encoding="utf-8"?>
<test:testReferral xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:test="http://www.example.com/test"
="https://www.example.com/test/bydp.xsd">
  <test:Details>
    <test:MessageVersionNumber>1.0.10</test:MessageVersionNumber>
    <test:From>Before You Dig Partners</test:From>
    <test:RequestMedium>Phone</test:RequestMedium>
    <test:UtilityID>10038</test:UtilityID>
    <test:StationCode>value1            </test:StationCode>
    <test:TicketNumber>20184200087</test:TicketNumber>
    <test:SequenceNumber>41199</test:SequenceNumber>
    <test:RequestDateTime>2018-10-19T12:02:21.295959-05:00</test:RequestDateTime>
    <test:WorkToBeginDate>2018-10-23T03:00:00-05:00</test:WorkToBeginDate>
    <test:WorkCompletionDate xsi:nil="true" />
    <test:IsEmergency>False</test:IsEmergency>
    <test:UserReference xsi:nil="true" />
    <test:StationList>
      <StationCode xmlns="test">value1             </StationCode>
      <StationCode xmlns="test">value2            </StationCode>
      <StationCode xmlns="test">value3            </StationCode>
      <StationCode xmlns="test">value4           </StationCode>
    </test:StationList>
  </test:Details>
I have tried using Feature paths for the configuratio Type and Elements to match to the node to Details .There is two entries with Previous Ticket Number and Previous Ticket Number.nil how would i handle this . which one should I keep0684Q00000ArMmvQAF.png
itay
  • Jan 27, 2019 8:23 PM UTC
Hello @itay
  <test:Details>
    <test:StationList>
    </test:StationList>
  </test:Details>
Hello @adi, the
itay
Hello @adi, the
bhanu_v
  • Jan 29, 2019 4:35 PM UTC
Hello @adi, the
Hello @itay,Thank you for your suggestion on this ,I removed the nil attributes from the user attribute list,but I still need to figure out xlmns tag ,I have a used a list exploder and that resulted in additional records where as opposed to only one.
bhanu_v
  • Jan 29, 2019 4:45 PM UTC
Hello @adi, the
Hello @itay,I have removed the xlmns tags from the attributes and I got the expected output.Thank you
