XML Parser error: 'unable to open primary document entity 'G:/GISMapping/FME/DBYD/LineRequests.gml''
The XML Module halted on error, see the logfile for details
I have a workspace that works fine with Desktop but fails with above errors when running through Server?
The gml works in Inspector just fine also.
  • August 16, 2017
The error could occur when the XML document does not exist in the specified file path. Firstly check if the "G:/GISMapping/FME/DBYD/LineRequests.gml" exists in the disk system of the Server machine.
  • August 16, 2017
Agree that you have to check that the file exists on the FME Server instance.
If G: is mapped to a network drive, you may also have to configure the FME Server Engine service to run as a domain user with appropriate rights to that particular network share, see
https://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/Running_FME_Server_Engines_Under_Different_Account.htm
