XML extraction
  • November 20, 2017
  • 8 replies
  • 16 views
Hello,
i've got this XML schema
and i want this
PRENOMNOMEMAILtest prenomtest nom
testemail.com
i've tried lots of thing s with XML flattener but nothing succeed.
can you help me
Thx
Best answer by trentatsafe
Hello @krowix,
Once you have read in the XML, there are one of two methods you could carry out to pivot your attributes/values. The easiest, I think, will be to use the AttributeTransposer. This is a custom transformer that can be found on the FME Hub: https://hub.safe.com/transformers/attributetransposer
It will allow you to re-map the attributes and the value based on an existing attribute.
I've attached a sample workspace that will carry that out based on a subset of your XML preview.
xml-transpose.fmwt
I hope that helps.
danilo_fme
Forum|alt.badge.img+45
  • November 20, 2017
Hi @krowix,
First i created manually your XML:
On FME Desktop Workbench:
Add the Data XML and select Parameters:
Feature Paths Configuration => Elements to Match:
You can use the Inspector to chack this:
Thanks,
Danilo
  • November 20, 2017
danilo_fme wrote:
Hi @krowix,
Thanks,
Danilo
thanks @danilo_inovacao but i want to have id value into attribute and valeur value into feature...
trentatsafe
  • November 20, 2017
Hello @krowix,
xml-transpose.fmwt
I hope that helps.
  • November 21, 2017
Hi @krowix, alternatively, the XMLXQueryExtractor with the following XQuery expression and other parameters setting could work for you. Assuming the attribute "xml_fragment" of the input feature contains the XML fragment <Metier>.
XQuery Expression
for $x in //Metier/Donnee
return fme:set-attribute($x/Id/text(), $x/Valeur/text())
Other Parameters
danilo_fme
  • November 21, 2017
trentatsafe wrote:
Hello @krowix,
xml-transpose.fmwt
I hope that helps.
Hi @trentatsafe,
I downloaded this custom transformer and it is powerful. Thanks to share us this knowledge.
Thanks,
Danilo
  • November 23, 2017
trentatsafe wrote:
Hello @krowix,
xml-transpose.fmwt
I hope that helps.
Hi @trentatsafe,
i've tried your solution and it's work very well !
Thx for all
  • November 23, 2017
Thanks for all your help and comment !!!
deanatsafe
  • January 16, 2018
There's also the FeatureBuilder custom transformer which will take a list of names and list of values and build records from them: https://hub.safe.com/transformers/featurebuilder
Don't forget for general info around reading and writing XML there is always the XML Tutorial: https://knowledge.safe.com/articles/29553/tutorial-getting-started-with-xml.html
