Writing data into an ESRI File geodatabase writing to a feature dataset
  • Jun 23, 2016 5:04 AM UTC
  • 948 views
I need to set up a workspace to write a file directly into a specific Feature dataset within an ESRI File Geodatabase - is there any way I can set this up.
  • Jun 23, 2016 7:18 AM UTC
Sure, when creating the output feature type, go to the format parameters tab and enter the name into the feature class creation parameters:
If the feature dataset does not already exist, it will be created for you.
timotheebecker
Forum|alt.badge.img+3
Hi @david_r
Interesting. As your post is fairly old, I wonder if it needs an update.
On my side, in FME 2021 and 2023, when I open the properties of a writer feature class, the window which opens is called Feature Type and not Feature Type Properties. In addition, this window doesn’t have the same thumbnails and I can’t find the Feature Dataset setting.
Here’s a screenshot of FME 2023.
weihong
  • Jun 20, 2024 7:52 AM UTC
hi @timotheebecker
As for FME 2023, the feature dataset setting has been merged with feature class:
Feature Datasets (safe.com)
Feature Type Name
The Feature Dataset name can be specified as part of the Feature Type name with the following syntax.
<Feature Dataset>/<Feature Class>
