write to PDF
  • Jun 14, 2018 12:20 AM UTC
  • 6 replies
  • 155 views
boubcher
Forum|alt.badge.img+11
How can I write attribute MSG to a PDF as text
ID MSG1inside the polygon2outside the area3close to the event area4comment
taojunabc
Participant
  • Participant
  • Jun 14, 2018 1:13 AM UTC
You need to first add the output coordinates of the text, then apply PDFStyler to determine the color of the text (if you need), and finally PDF output to PDF Writer.
boubcher
  • Jun 14, 2018 2:22 AM UTC
how the position of th text is defined on the pdf
boubcher
  • Jun 14, 2018 2:23 AM UTC
Forum|alt.badge.img+63
The VertexCreator makes fake geometry to attach the text to. You could add a PDFPageFormatter right before the writer to determine where the text ends up on the page.
boubcher
  • Jun 14, 2018 12:22 PM UTC
I get an error message ( invalid geometry ) just after the vertex transformer, is there any reason?
gio
Forum|alt.badge.img+15
  • Jun 14, 2018 3:35 PM UTC
use "replace" as parameter on the vertexcreator (not "add")
