write text into PDF
  • Jun 14, 2018 4:09 PM UTC
  • 322 views
boubcher
Forum|alt.badge.img+11
hello there
at the end of a transformation process, we have an attribute name msg_ar we want to write as text into a PDF file , I used the PDF formatter and the PDF styler but no success
Please any idea
Thanks
Forum|alt.badge.img+63
So create points for the labels you want to place, aligning them vertically and then using the LabelPointReplacer to place your label. After that it's styling and put it on the page.
write-to-pdf-rg.fmwt
On a side note, opinions vary but I am not a fan of renaming transformers in the interest of long-term maintainability of the workspace and making it easier for others to edit your workspace.
boubcher
  • Jun 15, 2018 1:04 PM UTC
@redgeographics
Thanks so much for your help
just to understand the logic
the vertex will create a point x represents the start of the text and Y is interline between each text, the text height is defined in the PDF styler transformer
is this correct
I did play with the factor your added into the Y coordinate but didnt see any diffrence
boubcher
  • Jun 15, 2018 1:11 PM UTC
if you change the msg_en by msg_ar , the arabic text , its not displaying on the PDF , I bleaive is an issue with the PDF writer ? any idea if there is any work around ?
Not the very thing you're looking for here, but why don't you mind of writing that data into the file after the process is ended? I can't claim it wouldn't have the further impact yet it will be easier for sure. Literally, just open the editor you have for such purposes (Acrobat, Phantom or else, from the cheap ones I use this one https://edit-pdf.pdffiller.com/ ) and put the parts were missing there. That doesn't solve the issue with the script, I see, but will come in use for time-saving purposes
