WorkspaceRunner and Maximum number of concurrent process limit
  • May 31, 2018 6:29 PM UTC
  • 126 views
jwe
I am wondering if there is any way to overcome the 7 concurrent FME process limitation of WorkspaceRunner? I am processing 2800 LAS files into DEM's (using a slightly modified version of the excellent example here) using a WorkspaceRunner being fed by a Directory and File Pathnames reader).
Our processing workstation has 16 cores and 64 gigs of ram... 7 concurrent instances of this workbench is only utilizing about 35-40% of my system resources, and it takes almost a day to get through all my files.
Is there any way (excluding upgrading to FME server for something that really doesn't need Server's capabilites) to get this running on more cores (or can someone help me figure out how to run it in a highly parallel fashion)?
Thanks!
  • May 31, 2018 10:00 PM UTC
Hi @jwe, I don't think there is a way to overcome the limitation. If you could transplant the entire workflow in the current child workspace into a new custom transformer, you could utilize the Parallel Processing functionality to launch multiple (maximum = number of cores x 2) child processes to run the workflow defined in the custom transformer concurrently. See also these links.
