Why my FME 2020 Doesnot Read IFCSpaces? When reading IFC Step Xml file with Read Ifcspace geometries' to Yes, but still not present in select feature Type. i tried on different IFC Files from Revit in FME 2020.
  • May 11, 2020 1:08 PM UTC
  • 103 views
Best answer by daveatsafe
Hi @fk9200815,
It is possible that there are no Spaces in the IFC file. Please check your Revit data to see if there are any Room features - these become Spaces in IFC. If you would like to share a sample of your IFC data, I would be happy to take a look at it for you. You can send it directly to if you do not want to share it publicly.
daveatsafe
Forum|alt.badge.img+24
  • May 11, 2020 4:10 PM UTC
Hi @fk9200815,
  • May 11, 2020 4:44 PM UTC
Hi daveatsafe
Thanks for your Quick Support, yes Isuue was with IFC export from Revit ,No room feature was exported.I solved it by Exporting again from Revit with Room features as IFC Step read as IFCSpace. Thanks for Support .
