why is filegeodatabase option is not active perhaps i have arcgis desktop installed
  • Jun 26, 2018 2:38 PM UTC
  • 58 views
hamdyahmed14
Best answer by trentatsafe
Hello @hamdyahmed14 ,
There are a couple of reasons why FME may not be registering that you have ArcGIS installed.
Are you using 32-bit FME or 64-bit FME? If you are using 64-bit FME, you will have to installed ArcGIS 64-bit Background Geoprocessing. This will allow FME to interact with ArcGIS's libraries. Alternatively, you could install 32-bit FME which would not require the ArcGIS 64-bit Background Geoprocessing.
Secondly, confirm your ArcGIS and FME are both licensed correctly.
Let me know if that does not solve the issue!
trentatsafe
Forum|alt.badge.img+7
  • Jun 26, 2018 2:53 PM UTC
hamdyahmed14
  • Jun 28, 2018 7:14 AM UTC
Thank you for quick reply . 32-bit FME installation solve the problem
