Which feature types to select for .KMZ file reader?
  • Dec 1, 2017 4:16 PM UTC
  • 163 views
dnguye1
Participant
I am trying to a .KMZ file format into my workspace using the GOOGLE KML reader. After I cliced OK, it prompts me with all these Feature Types (AnimatedUpdated, Document, FlyTo,....) I am not sure which to select. I am following the link @ https://knowledge.safe.com/articles/19918/how-to-expose-feature-attributes-from-kml-tag.html to connect the reader to the HTMLToXHTML Converter but I can't get the reader to load the correct file. Thanks for any helps.
erik_jan
Forum|alt.badge.img+26
  • Dec 1, 2017 4:28 PM UTC
This is the KML documentation: KML doc
Hope it will help you.
dnguye1
Participant
  • Participant
  • Dec 1, 2017 4:55 PM UTC
Thanks Erik. I'll look through the document.
gina_mills_1723
Antero_Midstream.kmzI am also trying to expose the attributes from a kmz file. I tried to follow the article, but cannot seem to get mine to work. I am attaching my kmz file here.
Forum|alt.badge.img+63
The data is stored in the Placemark feature type, the kml_parent attribute refers to the Folder feature type (corresponding with kml_id on the Folder), so you should do a FeatureMerge on those and then the kml_name you get out of the Folder is what you would call layername.
Bit short on time right now otherwise I'd make you an example, but I hope this helps.
