When i try to copy a table from a sde database to another sde database i get an error
  • Jan 13, 2021 6:04 PM UTC
  • 157 views
shivs
Forum|alt.badge.img+4
When i try to copy a table from a sde database to another sde database i get the following warning.
"Could not find the features in the table 'tablename'. One possible reason is that a WHERE clause was specified that references a column/field that does not exist in the table. The error number from ArcObjects is: '-2147216086'. The error message from ArcObjects is: {Attribute column not found [tablename][STATE_ID = 797]"
Also i get info "2021-01-11 17:05:12|  0.6| 0.0|INFORM|MULTI_READER(MULTI_READER): Will fail with first member reader failure"
Can someone tell what am i doing wrong here ?
@shivshreyes​  Are you using a WHERE clause in the Geodb reader parameters or the Feature Type parameters? Check the syntax of the WHERE.
shivs
  • Jan 13, 2021 8:28 PM UTC
No i do not have any where clause specified while copying
