What is the purpose of the extra xsi_nil attributes from a GeoServer WFS source?
  • Mar 30, 2020 4:06 PM UTC
  • 246 views
Can anyone explain the purpose of the extra xsi_nil attributes that accompany a Web Feature Service (WFS) data source?
For example, when I create a WFS reader in FME for the topp:states demo layer of a stock GeoServer, the resulting table schema in my FME workspace includes extra attributes - one for each native attribute - named <attribute>_xsi_nil. Here's a screenshot highlighting the fields in question:
The data type for all of these xsi_nil fields is xml_boolean. This happens for all WFS layers I consume from a GeoServer.
What is the purpose of these extra fields?
And is there a way to configure the reader - or the GeoServer layer - to not cause these extra fields to be created?
Thanks
  • Mar 31, 2020 8:58 PM UTC
Not an answer but a continuation of this topic ...
After some more research, it's clear these extra fields are added when the fields are defined as nillable in the xsd schema:
When I customize the xsd schema for this layer on the GeoServer, changing the nillable attributes to false, and then create a new WFS reader in FME, the extra xsi_nil fields are no longer present.
And after some research on the GML spec, I find that xsi_nil is an XML attribute used to indicate a nil value for an element instance, e.g.,:
<topp:SUB_REGION xsi_nil="true"></topp:SUB_REGION>
Is that the purpose for these extra fields in FME?  To accommodate the xsi_nil attribute setting?
Thanks
  • Mar 31, 2020 9:01 PM UTC
Thanks
Sorry, I see where I should have added the above as a comment to my original post ... my bad.
  • Apr 20, 2020 7:38 PM UTC
Thought I'd give this post a kick. Can anyone at Safe Software give some insight on this?
