What is the faster way to run an OSM (xml) data to Esri geodatabase data for a big area with FME?
  • Nov 23, 2017 4:03 PM UTC
  • 118 views
Dear Sir/madam,
I am student, working on OSM highway(poly_line) xml data with respect to the keys Max_speed and surface for the whole Africa.
In this case; I took at first, the Geometry Filter with line and I used 2 list_searchers for max_speed and surface respectively. And also use 2 attribute_creator for output. This way is working to get a Geo-database file which i can use on Arcmap. But it takes a long long time to read the data because of XML data.
Could you please help me to find the faster way or model to run the XML data? OR a faster way by using PBF format in this purpose in FME?
Thank you.
Sincerely Yours,
Yasin
Best answer by david_r
Try using an AttributeExposer and expose the "maxspeed" and "surface" attributes, e.g.
The attributes are documented in the OSM wiki:
jdh
Forum|alt.badge.img+41
  • Nov 23, 2017 4:35 PM UTC
I use the commandline tool OSMFilter to create a smaller OSM file with only the features I'm interested, prior to reading with FME.
  • Nov 27, 2017 11:07 AM UTC
Starting with FME 2017 you can read the PBF format directly, I would suspect that's faster than XML. By how much, I'm not sure, however.
Otherwise I completely agree with @jdh about reducing the data volume before processing with FME.
  • Nov 28, 2017 11:11 AM UTC
