What can be usedsimilar to FeatureReader transformer to read schema and data?
marias
Forum|alt.badge.img+8
I need to extract TAB or Shape file from S3 and read data from it including schema.
I have discovered in this article
https://community.safe.com/data-7/how-to-extract-the-actual-shapefile-from-featurereader-geometry-and-attributes-14548?tid=14548&fid=7
that FeatureReader apparently can’t read all attributes that are in the file, until I expose them. But what is I don’t know the list of all attributes? I don’t know what exactly will be uploaded by other people to S3 bucket, I just need to read the file.
Could you help, please, to identify the correct settings of FeatureReader or another way to extract data?
Best answer by crystalatsafe
Hi @marias
Most readers can select a file from a web/cloud location.
If you need to work with the Schema after reading in the data, you can then try the SchemaScanner transformer.
Let me know if this works for you.
Crystal
crystalatsafe
Forum|alt.badge.img+19
  • April 30, 2024
Hi @marias
Crystal
marias
  • May 17, 2024
crystalatsafe wrote:
Hi @marias
Crystal
Thank you
