WFS Reader - change credentials
  • September 10, 2018
  • 62 views
oliver.morris
Forum|alt.badge.img+12
I am using a WFS reader and would like to change the credentials at a later stage. Is it possible to do this after the reader has been added, currently I don't see any method to do so.
Thank you,
Oliver
Best answer by danilo_fme
Hi @olivermorris
I believe you can work with publish parameter.
Once the Reader WFS as added in your Workspace, go to Navigator -> Parameter -> Network Authentication - enable the option :
Now, you can generate two Publish Parameter for the attributes: Username and Password.
Enable the option Set Workbench To Prompt Before Running Workspace.
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+45
Hi @olivermorris
Thanks,
Danilo
oliver.morris
  • September 11, 2018
danilo_fme wrote:
Hi @olivermorris
Thanks,
Danilo
Thank you so much for the help, this worked a charm.
danilo_fme
Hi, I'm happy to help you :)
