Use wildcard within a test clause
  • May 13, 2020 1:16 PM UTC
  • 758 views
Hello,
I would like to use a wildcard within a conditonal statement. But I don't know if this is possible.
For example, I have the following records:
MeldingFor object(s) 001, 002 the date dd-mm-yyyy is later than de original date dd-mm-yyyy.
For object(s) 001 the date dd-mm-yyyy is later than de original date dd-mm-yyyy.
For object(s) 002, 004 the date dd-mm-yyyy is later than de original date dd-mm-yyyy.
I would like to use a conditional statement that gives me recors 1 and 3. So in this case it will become:
Instead, I would like to use a wildcard, so that I only need one test clause. Because in my dataset a lot more combinations are possible.
Is it possible to use a wildcard so that the test clause can become like this?
(I know that % doesn't work, but I use it here to give an idea what I would like to accomplish).
Thanks in advance,
Eva
Best answer by bwn
Use the Like operator, which will support % as a wildcard character.
Note:
  • Set the Case Sensitivity to what you desire, case sensitive or case insensitive.
  • May 13, 2020 1:55 PM UTC
I think the Contains Regex operator is suitable to your requirement.
Regex example:
^For object(s) \d+, \d+ the date
Perhaps is this one better?
^For object(s) 00\d, 00\d the date
bwn
Forum|alt.badge.img+26
  • May 14, 2020 3:23 AM UTC
Note:
  • May 14, 2020 11:50 AM UTC
Note:
Thanks @bwn, this is what I needed :-)
bwn
  • May 14, 2020 5:17 PM UTC
No problems. Note the solution from @takashi will be better for the more general purpose applications of where instead you want to find any combination of 3 digits, whereas the Like solution above fits your specific samples, is simpler to write, but is nonetheless more restrictive.
