Update writer schema from reader schema changes
  • Feb 1, 2017 10:23 PM UTC
  • 147 views
brooks
I am trying to figure out a way to update the schema of a writer after changes are made to the schema of a reader. In this case, there are no transformers, just a reader pointing directly to a writer. The name on the writer is different from the reader but that is the only difference. Occasionally a field length will change on the reader or a new field is added to the reader. I can bring those changes into the workspace by updating the reader, and I am looking for a way for the change attributes of the writer if the reader changes.
erik_jan
Forum|alt.badge.img+26
  • Feb 1, 2017 10:29 PM UTC
The easiest I can think of is: After updating, right click the Reader feature type and use "Duplicate on Writer".
Then remove the original Writer feature Type (or do that first)..
brooks
  • Feb 1, 2017 10:38 PM UTC
I was hoping I could use the workbench as part of an automated script so running it would update the destination schema and not have to get in and fiddle with it each time. Also, Duplicate on Writer wouldn't use the new feature names on the writer.
itay
Forum|alt.badge.img+19
  • Feb 1, 2017 10:39 PM UTC
my choice would be to set up a dynamic translation which will take care of the schema changes.
