Update sharepoint list
  • May 31, 2018 11:22 AM UTC
  • 8 replies
  • 169 views
owen
Hi FME fans,
I am using the MS Sharepoint List writer to update values - this is using Feature Operation 'Update' using Row Selection 'sharepoint item id'.
This works fine when I give it a new value, eg a different date, however if I set the value to null in FME the value in sharepoint doesnot change. How can I set the value to null?
Thanks,
Owen
itay
Forum|alt.badge.img+19
  • May 31, 2018 3:09 PM UTC
Hi Owen, this sounds logical since a null value will not be found in the item id, or am I missing something?
owen
  • May 31, 2018 3:14 PM UTC
Hi Itay, no this isnt updating the item id, but other attributes. Basically I want to clear these attributes out, not update them but setting the values to null doesnt trigger any change
itay
  • May 31, 2018 3:16 PM UTC
Any chance 'missing' or empty values work better?
lars_de_vries
Forum|alt.badge.img+10
Can it be that the date field is an obligatory field and that null-values aren't accepted?
owen
  • Jun 5, 2018 8:39 AM UTC
No, joy with missing or empty values
owen
  • Jun 5, 2018 8:40 AM UTC
Hi Lars, thanks but no it can have blank/null values in the field
erivero
Participant
  • Participant
  • Mar 23, 2023 4:28 PM UTC
@owen​ did you ever find a solution? I'm facing the same issue
bellalistair
Participant
  • Participant
  • Oct 17, 2024 3:24 PM UTC
After a few abortive attempts at ever more complex solutions to this precise problem (SharePoint list value needing to be cleared as an update) I have found a solution, at least for single line text fields.
Use a NullAttributeMapper to map null to a carriage return
The Writer then has “something” to write and so does include that in the JSON payload, but SharePoint ignores it since it isn’t valid.
No help for multiline fields of course but hopefully helpful.
Why it took me so long to think of this I don’t know, I’d tried mapping empty strings and all sorts of custom writers, but the simple solutions are the best.
