Update CAD with Excel
  • Jun 24, 2015 4:42 AM UTC
  • 52 views
afod
I am trying to do a really basic function.
I have a CAD file which i add an attribute to and populate with the fme_basename.
I then have an EXCEL that contains the fme_basename and also another field called 'DESCRIPTOR'
basically what i want to do it a test where FME says If the fme_basename = the Basename from excel then populate new field with the value from descriptor. I have used an attribute creator with a conditional value but does not seem to work?
Best answer by takashi
The FeatureMerger or the Joiner might help you, if your requirement is to add a descriptor to a CAD feature when its fme_basename matches the basename which is associated with the descriptor in the Excel table.
Takashi
  • Jun 24, 2015 5:35 AM UTC
Takashi
