Tryging to read Postgres 14 with FME 2023 but getting "Failed to retrieve feature types"
  • Jun 3, 2024 4:33 PM UTC
  • 220 views
anteboy65
Forum|alt.badge.img+4
I’m running FME Form 2023 and creating a new script with a reader wich fails when looking up tables. Message given:
Could not open the enterprise geodatabase because the local version of arcgis is not compatible with the server's SDE version.
On the laptop I have both Arcmap 10.7 and ArcGIS PRO 3.1 (AGP) installed. When creating the reader I use a connection file created in AGP. I also have FME 2018 but this is 2023. The reader is defined as “Esri Geodatabase (ArcSDE Geodb) / Embed Connection Parameters” as the geometry format in the database is ST_GEOMETRY.
To me it looks like files from ArcGIS 10.7 is found and used which doesn’t work. Is there any way to force FME 2023 to use “library files” from AGP 3.1 or is there another way to solve the problem?
Best answer by hkingsbury
In the navigator, check what ‘Esri ArcGIS Compatibility’ is set to
You may need to change it to the Pro option
hkingsbury
Forum|alt.badge.img+73
  • Jun 3, 2024 9:51 PM UTC
anteboy65
  • Jun 4, 2024 10:00 AM UTC
Thanks! That did the trick.
