Transfer data from mdf “Enterprise geodatabase” to gdb
  • Apr 20, 2015 7:16 PM UTC
  • 62 views
ahmad_saleh
Hello All,
FME workbench to transfer data from mdf “Enterprise geodatabase”  to gdb
I am trying to develop a workbench that will be able to replace the existing data (FC,Tables,Datasets,…) in a File geodatabase “gdb” by the one coming from the mdf “Enterprise geodatabase”.
Is this can be done using FME ? if yes how can I start ?
Regards,
Ahmad
  • Apr 21, 2015 1:38 PM UTC
yes, it's quite simple, as long as FME can read the "mdf" format.
Start a blank workspace, add new reader using the menu Readers / Add reader. Specify input data.
Add a gdb writer using Writers / Add writer. Make sure to specify to import data defintion from existing gdb, if relevant:
Then simply drag connection lines between the feature types and the attributes.
Consider watching some of the free recorded webinars to get you started:
http://www.safe.com/learning/training/
Documentation starting point: https://knowledge.safe.com/KnowledgeDocumentation
David
ahmad_saleh
  • Apr 22, 2015 8:56 AM UTC
Hi David,
Thanks for the information I will try to devolp the workbench and keep you posted.
Thanks,
Ahmad
