The Transformer Emailer causes error message on our mail server
The Transformer Emailer causes the following error message on our mail server:
2018-05-17T22:22:23.651384+02:00 warning: Illegal address syntax from xxx.xxx.de[xxx.xxx.xxx.xxx] in RCPT command: <>
Unfortunately I do not have any further information about our mail server. I don't care about the error message, but the guys from the central IT pressure for this error message to disappear. Is it possible to make changes to the email settings and if so, where? With REST?
Forum|alt.badge.img+53
A quick google shows that it might be related to accented characters in the email address (and assuming you are from Germany that's actually rather likely). That would mean they would get the same error if you try and send email to such an address through other means than the Emailer transformer and that in turn would mean it's not really an FME issue.
There appear to be fixes available for a mailserver to support UTF8 characterset in email addresses. From what I can gather it's mainly Postfix that has this issue and there's an upgrade package called SMTPUTF8 available for it.
  • June 11, 2018
The email addresses used do not contain any special characters, such as accents or umlauts. This cannot be the reason. In addition, both variants were tested as described in the documentation.
"Safe support" <support@safe.com>
support@safe.com
See also https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/emailer.htm
