The need to creating *.gdb before converting dwg files to ESRI feature classes,
  • Apr 27, 2015 5:22 PM UTC
  • 78 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out if I need to create first *.gdb I order to be able to convert dwg files to feature classes stored in file geodatabase. Does this mean that I need to have ArcGIS, for example, installed in my machine to do so?
Thank you
Best
Jamal
Best answer by takashi
The writer creates new GDB dataset when you run the workspace.
Enter the gdb name into the "Geodatabase (.gdb) Folder" field directly, if it doesn't exist yet.
  • Apr 28, 2015 10:51 AM UTC
jamal
  • Apr 28, 2015 5:36 PM UTC
Thank you Takashi. It works fine
