Text moving in Y direction
  • May 24, 2013 1:02 PM UTC
  • 47 views
I want to move text  the in Y direction,using the line as a base(text created along the line nodes already) how to mve this?
  • May 24, 2013 1:38 PM UTC
Hi Vijai,
have a look at the Offsetter transformer.
Takashi
  • May 24, 2013 1:43 PM UTC
Possible to explain in flow chart?
  • May 26, 2013 4:23 AM UTC
there are not many things that should be explained about the Offsetter.
Input the features which you need to move into the INPUT port, and specify preferable amount for moving as X / Y / Z Offset parameters. Then the transformer will output moved features. If you still have any questions after trying, feel free to post those again.
Takashi
