String replace with multiple value result.
  • Nov 24, 2022 1:51 PM UTC
  • 6 replies
  • 509 views
kidega
Forum|alt.badge.img+9
I have a scenario with a random string test;
"Häradålderön" which my goal is to se the result to "Haradalderon".
Basically replace any [ä, å, ö] with [a, a, o] letter.
I guess using regular expression could do it, but I find it tricky since it might be three sequences to search for ä, å, ö. Any ideas appreciated!
  • Nov 24, 2022 1:57 PM UTC
Did you have a look at the StringDiacriticRemover from the Hub? I believe it should do what you're looking for: https://hub.safe.com/publishers/safe-lab/transformers/stringdiacriticremover
Forum|alt.badge.img+54
  • Nov 24, 2022 2:27 PM UTC
Have you looked at the StringPairReplacer?
kidega
  • Nov 24, 2022 3:56 PM UTC
Haven't looked into this yet, thanks for the suggestion!
kidega
Great! This was a very easy solution, thanks!
pradip
Forum|alt.badge.img+3
  • Jun 29, 2023 10:21 AM UTC
kidega
  • Jul 28, 2023 3:53 AM UTC
