SQL Server JDBC issue in SQL Executor
  • Jul 16, 2018 10:42 AM UTC
  • 7 replies
  • 93 views
oliver.morris
Forum|alt.badge.img+14
Morning,
When I run the following using sql executor using the SQL Server Native client I get back a result.
EXEC	[dbo].[SP_API_VALID_SUBSCRIBER]
@modules = N'1,2,3,4,5,6,7,8,9',
        @clippolygon = N'POLYGON ((-168.046875 -85.62206859340185,183.515625 -85.62206859340185,183.515625 83.35951133035452,-168.046875 83.35951133035452,-168.046875 -85.62206859340185))';
When I run the same query using the JDBC driver for SQL Server no spatial I get no results back, although the sql execution was successful no results are returned. I have tried with and withougt the 'commit;' at the end of the script and this has no effect.
Does anyone have any ideas why this might be?
Many Thanks,
Oliver
ravenkopelman
Hi @olivermorris, what version of FME did you see this in? Something similar was reported against FME 2015 but we could not reproduce against FME 2017 and did not pursue further.
oliver.morris
  • Jul 16, 2018 4:56 PM UTC
Fme 2018.0 thanks
ravenkopelman
Fme 2018.0 thanks
There was a big driver upgrade in FME 2018.1 that might impact this. We will take another run at reproducing and see what we can do. Thanks for reporting!
oliver.morris
  • Jul 20, 2018 9:48 AM UTC
Tried with 2018.1 this morning and still get the same result. Works with native client not with jdbc.
xiaomengatsafe
Forum|alt.badge.img+11
Hi @olivermorris, our team is working on trying to reproduce the issue. Just a couple of questions:
  1. Can you confirm that you've tried the query using Microsoft SQL Server Spatial (JDBC), in SQLExceutor? If you haven't can you give it a try?
  2. If the above attempt doesn't work, can you send us the stored procedure? We tried to reproduce this issue using a simple mock stored procedure, but got the result back. So knowing what your stored procedure is like will help us reproduce the problem.
Thank you!
oliver.morris
  • Jul 24, 2018 1:03 PM UTC
Thank you!
I tried point 1. no change no response back.
The stored procedure should just return a field called subscriber and the value is 1
@modules = N'1,2,3,4,5,6,7,8,9,10,11,12,13,20,21,22,23,24,26,27,28,29,30,32,34,36,38,40,41,43,45,46,48,49,51,53,55,57,59,61,62,63,64,65,66,67,68,69,70,71,95,96,97,98,99,100,101,102,103,104,105,106,107,108,109,127,128,129,130,131,132,133,134,135,136,137,138,139,140,141,142,159,160,161,162,163,164,165,166,167,168,197,201,206,207,208,209,210,211,212,213,214,215,216,217,218,219,221,224,225,243,244,251,252,253,254,257,258,259,260,261,262,263,264,265,266,267,268,269,270,271,274,275,277,278,279,280,281,282,283,284,285,286,287,288,289,290,291,298,302,303,304,305,306,307,308,309,310,311,312,313,314,315,316,317,318,319,320,321,322,323,324,325,326,327,328,329,330,331,332,333,334,335,336,337,338,339,340,341,342,343,344,345,346,348,349,350,351,354,356',
The full stored procedure is attached.sql.txt
Thank you for all your help, if you have any questions please let me know.
Thanks,
Oliver
xiaomengatsafe
Thanks,
Oliver
Thank you very much @olivermorris, for the details you provided! Our team will be investigating this issue, and we'll post updates here.
