Split the table multiple tables
  • September 25, 2015
  • 53 views
Say I have a massive table (+15million lines) with multiple columns , it has a Field called "category"..the category Field has multiple data values in it.
how do i split the table based on the field category? say the field has 150 categories in it..therefore I need to have 150 tables.
so if the input is 1 csv file.. the output required is 150 csv files separated per category.
I think this could be a test filter with so many filters in it.
thanks in advance.
kind regards,
Jubert
Best answer by takashi
Hi Jubert,
You can set the value of "category" as destination feature type name (i.e. output CSV file name) in the CSV writer feature type properties.
Takashi
Hi Jubert,
Takashi
Thanks Takashi! you are always as helpful... im going to try to split the 15million points problem I am having as I couldnt still figureout how to do it...whether i am using PointonAreaOverlay or Spatial Filter method it just takes too much time...
previous problem:
 https://knowledge.safe.com/CommunityAnswers?id=906a0000000dDva
thanks so much for your help Takashi
