Sort Directory. Need to read multiple file types and write them out.
  • Apr 2, 2020 10:27 AM UTC
  • 89 views
I'm trying to sort through huge amounts of data.
I have already run a directory file reader and have a huge CSV full of all the possible files in a directory including their name, path and extension etc.
I now would like to push those file types into a new folder.
This is for non-spatial, so a different folder for csv's, xsl, xlsx, doc, jpeg etc etc
By doing this I can then investigate these futher.
Work so far:
Reader: Read all files in directory and sub-directory that are, for example, a .csv
I get an error and it won't create the reader, so I create it as a single CSV and then change the directory to the folder with \\**\\* at the and so it looks through all sub-directories.
Writer is set to Dynamic and the same file type.
I get errors from any of the above workings.
Alternatively I feel like the original csv I have with all the directories included (including file path and extension) could be utilised for this?
When I pull that CSV in it shows up like this instead of broken down, so I can't run a TestFilter.
Any help appreciated.
Forum|alt.badge.img+54
  • Apr 2, 2020 10:37 AM UTC
If you just need to move/copy files to a new location it's not necessary to read them. The filecopywriter will let you do this from the csv file you're already produced.
Hi, could you expand on this a bit more? I can't work out how that works.
  • Apr 9, 2020 9:16 AM UTC
So if your start point is a csv file with information about files, their extensions and locations
Read the csv file
test the attribute that holds the extension so you only keep the csv files
create 3 new attributes
filecopy_source_dataset - the location of the original file to be moved
filecopy_dest_dataset -the new folder you want the file moved to
filecopy_dest_filename - the name you want the new file to be called (this can just be the same as the existing)
send to the file copy writer
